| Version(s): | 08.11.09.XXX(SS5) |
| Environment: | Windows 7/8.1 (64 bit) |
| Area: | Schema |
| Subarea: | - |
| Original Author: | Michelle Saucier, Bentley Product Advantage Group |
To add a new category with a pull down in OpenPlant Modeler from Class Editor.
communities.bentley.com/.../12020.schema-openplant-modeler
Bentley's Product Advantage Group requests that you please submit any comments you have on this Wiki article to the "Comments" area below. THANK YOU!
