4. SITEOPS Swept Path
Do you have difficulty revising plans based on vehicle path requirements?
The SITEOPS® Swept Path analysis realistically simulates vehicle path movement throughout the site design process and identifies vehicle path issues early in the project before they lead to costly design revision.
The Swept Path incorporates a pre-populated library of vehicle templates from AASHTO 2004 (U.S.) and gives users the ability to design custom vehicle templates, such as articulated semi-trucks or buses, which can be saved to a personalized, central database shared with other users in a firm or company. The output contains the center, wheel paths, swept path and vehicle images on separate layers and, as the standard in SITEOPS software, can be exported as DWG, Land XML and PDF formats allowing for easy use in other leading CAD programs.
