5. SITEOPS 3D Visualization
Do you have trouble trying to get your client and stakeholder understand the intent of your design?
The SITEOPS® 3D Visualization allows for users to create amazing visualization models by the click of button.  Using the power of SITEOPS and LumenRT will let you deliver the images and videos that will let the stakeholders become immersed in the enlivened environment of your design.
If a picture is said to be worth a thousand words then an interactive 3D visualization if worth a millions words and for your client could be worth millions of dollars.  Users can place LumenRT models, cars, people, trees and plants, into the SITEOPS model.  As the user changes to design the models will change as the model changes.  No need to manually update your 3D model with each revision, SITEOPS 3D Visualization take care of that tedious task for you allow you to spend more time designing.
https://youtu.be/FlxNgnW5Ev0
