| Product(s): | OpenPlant Modeler | ||
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.XXX (SS6) | ||
| Environment: | Windows 7/8.1/10 (64 bit) | ||
| Area: | Component | ||
| Subarea: | Properties | ||
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
Normally, in OPM when we place mating flange with different FACING, an error is displayed in the message center saying "Components not Compatible. Component properties do not match: FACING". But in some cases you have to place the mating flange with different facing and this article will explain what changes are required.
For example we will review, weld-neck flange which has RAISED_FACE and FLAT_FACE facings.
Setting in Managed Workspace
