Applies To | |
Product(s): | AutoPLANT Modeler |
Version(s): | N/A |
Environment: | Windows 7 32 bit, Windows 7 64 bit, Windows XP 32 bit |
Area: | N/A |
Subarea: | N/A |
Original Author: | Joey Bertone, Bentley Product Advantage Group |
How to change the version of AutoCAD used on startup
Both Document Manager and Vision use the data in AT.ini to determine the version of AutoCAD and what profile is used to open AutoPLANT. By default when AutoPLANT installed the newest version of AutoCAD available on each computer; because of this the AT.ini can point to a version or variant (LT, MEP, Map 3D, etc…) of AutoCAD that is not supported.
AT.ini file location
Windows 7
- C:\ProgramData\Bentley\Plant V8i\CFG
Windows XP
- C:\Documents and Settings\All Users\Application Data\Bentley\Plant XM\CFG
Because of its location at.ini is not project specific it is workstation specific.
Changing the AutoCAD version
- Open the AT.ini
- Find the [PIPING] section
- Locate the CADAPP section
- Change the CADAPP path to reflect the version of AutoCAD that is supported. Example:
- Change from: CADAPP=C:\Program Files\Autodesk\AutoCAD 2013\acad.exe
- Change to CADAPP=C:\Program Files\Autodesk\AutoCAD 2012 - English\acad.exe
- Locate AcadCmdLine
- Change the AcadCmdLine path to reflect the version of the AutoCAD profile in use. This step may not be needed. Example:
- Change from: AcadCmdLine=/p "C:\ProgramData\Bentley\Plant V8i\AutoPLANT_SS3_PDW811ACAD_B001_409.arg" /b loadpiping
- Change to: AcadCmdLine=/p "C:\ProgramData\Bentley\Plant V8i\AutoPLANT_SS3_PDW811ACAD_A001_409.arg" /b loadpiping
- Change each section that have CADAPP and AcadCmdLine and save the file. Once changed the save the file and opened files from document manager and vision will open the requried AutoCAD.
Other AutoPLANT Modeler profile versions
- AutoCAD 2012
AutoPLANT_Modeler811ACAD_A001_409.arg
- AutoCAD 2013
AutoPLANT_Modeler811ACAD_B001_409.arg
- AutoCAD 2014
AutoPLANT_Modeler811ACAD_D001_409.arg
- AutoCAD 2015
AutoPLANT_Modeler811ACAD_E001_409.arg
- AutoCAD 2016
AutoPLANT_Modeler811ACAD_F001_409.arg
Product TechNotes and FAQs
External Links
Bentley LEARN Server
Comments or Corrections?
