| Product(s): | AutoPLANT Modeler - Project Packager |
| Version(s): | |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | General |
| Subarea: | |
| Original Author: | Kestutis Mitkus, Bentley Product Advantage Group |
When requirement raises to package several projects automatically, instead of going through the Project Packager Wizard for each project separately, there is possibility to use several commands in command window. In this Example a batch file will be created, which can be used to package required projects.
To package required project using command window, ProjectPackager.exe should be run with 6 command line parameters.
| Mode |
/P for packaging /U for unpackaging
| Zip File name and path | C:\Testing Projects\Test1.zip |
| Project Root | C:\Testing Projects |
| Project ID | 0001 |
| User name | Supervisor |
| Password | Supervisor |
- Create *.bat file with commands in it to package required AutoPLANT projects:
pushd C:\Program Files (x86)\Bentley\Plant V8i\Bin
ProjectPackager.exe /P "C:\Testing Projects\Test1.zip" "C:\Testing Projects" 0001 Supervisor Supervisor
ProjectPackager.exe /P "C:\Testing Projects\Test2.zip" "C:\Testing Projects" 0002 Supervisor Supervisor
popd
- Open CMD and type in batch file running command:
C:\Testing Projects\ProjectsPackager.bat
If path contains directories with spaces in their names, then you might get same message. In this case a short path can be used instead. To check what Short path name is for required directory open CMD, go to required directory and with dir/x command populate information about all directories
cd C:\
dir/x
In this example Short path name isTESTIN~1
C:\TESTIN~1\ProjectsPackager.bat
- After launching this batch file all defined projects will be packaged one by one without need of going trough Project packaging wizard.
Comments or Corrections?
