Moving license activation
Product(s):Cube
Version(s):6.4 to 6.5
Area:Licensing
Cube uses a 16-digit license code for license activation. To move license activation from one computer to another, the licenses have to be deactivated on the existing computer and then activated on a new computer.
Deactivate the existing activation
1. Open license manager from Windows search.
2. Right click on the license package which you would like to deactivate, and select Deactivate. You need to be connected to the internet to deactivate the license.
3. A successful deactivation should remove the license package from the license manager
Activate on the new computer
1. Open license manager using Windows search
2. If there are no existing licenses on the new computer, the license manager will prompt the user to activate the license. Click on Activate a license Key. If you are not prompted for license activation, go to Menu >> Activate a License Key...
3. Enter the 16-digit activation key and click OK.
4. If the activation is successful, the license package for that license key will be listed in the license manager.
