To access the Column Chooser utility to customize the column headers in the dashboard of WorkFlow Manager, right click inside any column header and select ‘Column Chooser’:
This will display the Column Chooser dialog:
Available column headers are listed in the Column Chooser dialog, and can be dragged from the dialog box to the location on the column header row and released. Existing column headers can be removed by dragging them from the column header row into the dialog box.
Extend the width of the headers by placing the cursor directly on the right hand end of the column, and when the cursor changes to a double-headed arrow, left click and hold while dragging to the desired width:
