CUBE Avenue is an additional module completely integrated within the CUBE Voyager modelling steps. Avenue uses standard CUBE Voyager commands and scripts, with high flexibility for the user, allowing tailoring the assignment for many purposes.
Image 1 - Module Structure
Avenue brings the Mesoscopic approach and Dynamic Traffic Assignment Equilibrium to CUBE, loading and tracking the movement of vehicles throughout the network.
As CUBE Avenue processes the various kinds of information used in traffic assignment, it moves between different levels of aggregation. On a disaggregate level, vehicle packets move, stop, and queue through upstream roads and intersections:
Then, Avenue estimates an aggregate measure of congested travel time based on vehicle density on road segments during each time increment. The total journey time then consists of:
Image 2 - Isolate queues by length and time
CUBE Avenue computes the lowest-cost path for each vehicle unit, based on its departure time, considering the link travel time corresponding to the time segment of the estimated entering time of the packet to that link.
Through an iterative process, CUBE Avenue calculates optimal network conditions at equilibrium.
Typically, the model converges in several iterations, with an extremely fast process for smaller systems and feasible for large urban areas. Indeed, modelers have successfully applied CUBE Avenue on areas with around 3,000 zones and 25,000 links.
The combined use of both static and dynamic processes in the same run can be accomplished through a Hybrid Static and Dynamic Traffic Assignment, including both dynamic and static elements.
Other than traditional types of analysis, considering aggregate outputs from the model, CUBE Avenue can provide two main additional layers for analysis:
Some of the potential applications are listed here below:
Image 3 - Hampton Roads Hurricane Evacuation Study (source: http://www.pilotonline.com)
Most urban areas can use existing data in their regional transportation model to implement CUBE Avenue. When collecting traffic data for DTA there are two additional components that needs to be considered:
Basic CUBE Avenue inputs include:
The outputs from Avenue are both numerical and visualization aids, with the ability to create 2D animation for bandwidths and vehicle circulation. When combined with CUBE Base, CUBE Avenue can help to analyze and visualize future operating conditions under various demands and road management strategies.
Image 4 - Volume bandwidths and vehicles animation
In terms of numerical results, CUBE Avenue produces performance measures for every specified time segment and for the entire modelled period. Output performance indicators include:
Moreover, data can be summarized with the charting and table functions in CUBE Reports.
Image 5 - Example of output report: queue length by time segment
Avenue provides detailed information on the movement of each packet through the network in a so-called “packet-log file”. By post-processing this output file in CUBE Voyager, many advanced analyses can be implemented:
Several visualization outputs and animations are also available:
Image 6 – Intersection detail by time and vehicles animation
