| Product(s): | AutoPlant AutoIsoGEN |
| Version(s): | |
| Area: | Other |
| 0 | Iso created successfully. |
| 1 |
The PISOGEN environmental variable |
| 2 |
Invalid style name. The specified style |
| 3 |
Invalid project name. The specified |
| 4 |
IDFGEN handshake failed - The |
| 5 | Obsolete - No longer used. |
| 6 | Obsolete - No longer used. |
| 7 | Obsolete - No longer used. |
| 8 |
ISOGEN handshake failed - The |
| 9 |
ISOGEN failed to produce a valid |
| 10 | Obsolete - No longer used. |
| 11 | Obsolete - No longer used. |
| 12 | Obsolete - No longer used. |
| 13 |
IDFGEN failed processing the PCF. |
| 14 | Obsolete - No longer used. |
| 15 | Obsolete - No longer used. |
| 16 | Obsolete - No longer used. |
| 17 |
Unable to copy the style's |
| 18 | Obsolete - No longer used. |
| 19 |
Personal ISOGEN handshake failed - |
| 20 |
Unknown Error in Personal ISOGEN. |
| 21 |
Unable to get the current working |
| 22 |
Unable to set the current working |
| 23 |
Invalid handshake mode. Error opening ISOGEN.FLS. Error opening message file. |
| 24 |
Unable to restore the current working |
| 25 |
Error opening I-GEN.FLS for reading Error opening ISOGEN.FLS for writing Error opening options file specified in I-GEN.FLS Error closing options file specified in I-GEN.FLS Error closing I-GEN.FLS Error closing ISOGEN.FLS Error opening I-GEN.OPL for writing Error closing I-GEN.OPL |
| 26 |
The isometric root directory is either |
| 27 |
Unable to set PISOGEN environmental |
| 28 | Invalid file extension |
| 29 |
When running in IDFGEN mode, the |
| 30 | Obsolete - No longer used. |
| 31 |
Error occurred creating a POD Error occurred during "pass 1" when |
| 32 |
Error occurred creating a POD Error occurred during "pass 2" when |
| 33 |
Failed to load PODGRAPHICS DLL – |
| 34 |
PODGRAPHICS process failed – i.e. a |
| 35 |
The data supplied to the POD module |
| 40 | |
| 41 | Unable to get system temp directory. |
| 42 |
| 43 |
Unable to set bore units to those |
| 44 |
Unable to perform macro substitution |
| 45 |
Unable to restore original style |
| 46 |
MESSAGE entry is missing from |
| 47 |
OPTION-SWITCHES-SHORT/LONG is |
| 48 |
Failed to copy remote OPL file to local |
| 49 | Failed to update ISOGEN.FLS. |
| 50 |
Project disk is full – unable to create |
| 51 |
File containing temp directory is full – |
| 52 |
Unable to determine bore units from |
| 53 |
Unable to copy a file from the style |
| 60 | The input file does not exist. |
| 61 |
An invalid file was supplied to |
| 62 |
ISOA2B conversion failed. Possibly a corrupt input file. |
| 63 |
IDFGEN has reported that the input |
| 64 |
| 1001 |
Requested units combination is |
| 1002 | Obsolete - No longer used. |
| 1003 |
Problem deleting an ISOGEN message |
| 1004 |
Line in the options file has invalid |
| 1005 | Too many switches in the options file. |
| 1006 | Too few switches in the options file. |
| 1007 | Obsolete - No longer used. |
| 1008 | Obsolete - No longer used. |
| 1009 | Obsolete - No longer used. |
| 1010 | Obsolete - No longer used. |
| 1011 |
Options file missing specified in |
| 1999 |
Isogen has returned a FAIL for one or This is only a WARNING. |
| 2001 |
Inconsistent units combination |
| 2022 |
IDFGEN has detected disconnected
| 2022 | |
| -1 |
Error in Isogen data. Check message |
| -2 |
Isogen dll failed to load (possible |
| -3 |
Isogen thread failed to finish – |
| -4 |
| -5 |
Failed to load ISOGEN dll or any of its |
| -6 |
Failed to load IDFGEN dll or any of its |
| -7 |
Idfgen dll has crashed during |
| -1001 |
Failed to create the specified Pre/Post |
| -1002 | Pre/Post Processor has crashed. |
| -1003 |
Pre/Post processor has timed out and |
| -1004 |
Pre/Post processor has timed out but |
