Note: suggested CUBE version 6.4.5 or later.
CONVERTMAT command allows to convert matrix files between the CUBE native 'TPP' format and the open matrix format 'OMX'.
The CONVERTMAT command should be used within a Pilot program with the following syntax:
Example of conversion from CUBE .MAT files to OMX is provided below:
convertmat from = "{SCENARIO_DIR}/HW_LoopSkims01_OP.MAT" to = "{SCENARIO_DIR}/HW_LoopSkims01_OP.omx" compression = 1 format = omxconvertmat from = "{SCENARIO_DIR}/HW_LoopSkims01_PK.MAT" to = "{SCENARIO_DIR}/HW_LoopSkims01_PK.omx" compression = 1 format = omxconvertmat from = "{SCENARIO_DIR}/PT_LoopSk01_OP.MAT" to = "{SCENARIO_DIR}/PT_LoopSk01_OP.omx" compression = 1 format = omxconvertmat from = "{SCENARIO_DIR}/PT_LoopSk01_PK.MAT" to = "{SCENARIO_DIR}/PT_LoopSk01_PK.omx" compression = 1 format = omx
Example of conversion from OMX to CUBE .MAT format is provided below:
convertmat from = "{SCENARIO_DIR}\mf31.omx" to = "{SCENARIO_DIR}\mf31.MAT" format = TPP ; "auto_trips_peak"convertmat from = "{SCENARIO_DIR}\mf32.omx" to = "{SCENARIO_DIR}\mf32.MAT" format = TPP ; "transit_trips_peak"convertmat from = "{SCENARIO_DIR}\mf33.omx" to = "{SCENARIO_DIR}\mf33.MAT" format = TPP ; "auto_trips_offpeak"convertmat from = "{SCENARIO_DIR}\mf34.omx" to = "{SCENARIO_DIR}\mf34.MAT" format = TPP ; "transit_trips_offpeak"
