| Product(s): | Cube |
| Version(s): | 6.1 to 6.5 |
| Area: | Network |
Occasionally, we would need to renumber the nodes for non-zonal and zonal cases after editing our network or introducing new zonal data, etc. There are various ways to do this. For this exercise, an example script was provided to show how it can be achieved via scripting.
;--- creating a lookup file for node numbering
;--- data fields: new# old#
COPY FILE=RENUMBER.DAT
101 1
102 2
103 3
104 4
105 5
106 6
107 7
108 8
109 9
110 10
ENDCOPY
RUN PGM=NETWORK
NETI[1] = INPUT.NET
NETO = OUTPUT.NET
;--- specifying input lookup file
LOOKUP NAME=RENUM, FILE=RENUMBER.DAT,
INTERPOLATE=F, FAIL=0,0,0
;--- modifying node numbers in nodes
PHASE=INPUT FILEI=NI.1
IF (RENUM(N)<>0) N=RENUM(N)
ENDPHASE
;--- modifying node numbers in links
PHASE=INPUT FILEI=LI.1
IF (RENUM(A)<>0) A=RENUM(A)
IF (RENUM(B)<>0) B=RENUM(B)
ENDPHASE
ENDRUN
