Applies To | |
Product(s): |
OpenPlant Isometrics Manager |
Version(s): |
08.11.11.224 (SS6) |
Environment: |
Windows 7/8.1/10 (64 bit) & others |
Area: |
Settings/Attributes |
Subarea: |
Isometric Content - Dimensions |
Original Author: |
Jaya Tiwari | Bentley Product Advantage Group |
During Isometric Drawing generation in Metric Project Unit, the Elevations are calculated into Millimeters. Sometimes, in user specific project they want Isometric to calculate and show into Meter unit. In this Wiki Article we will see how to change Millimeters unit into Meters in OpenPlant Isometric Manager.
Open Style.cfg File. Browse from below highlighted location, here Project Unit is Metric.
Add below Variables
Save Changes.
Generate Iso-Sheet & Verify Results.
NOTE: After performing above steps all Units present in Isometric will get changed into Meters.
communities.bentley.com/.../modifying-text-and-annotation-settings
