How To Add Custom Property in Pipeline Tag in OpenPlant PID
Product(s):OpenPlant PID
Version(s):08.11.10.XXX & Higher
Environment: Windows 7/8/10 (64 bit)
Area: Customization
Subarea:
Original Author:Deepak Singh, Bentley Product Advantage Group
User requirement is to add custom property in pipeline tag, also created custom property must have ability to select its defined values through a drop down list.
  1. Launch Bentley Class Editor.
  2. Open OpenPlant PID schema of desired project, say here metric.
    Path: C:\ProgramData\Bentley\OpenPlantPID (SS6)\WorkSpace\Projects\OPPID_Metric\Dataset\schemas
  3. Navigate to PIPING_NETWORK_SYSTEM class. Switch to Properties tab.
  4. Click on Add > New to add a property
  5. Add a new property INSULATION_TYPE as shown below.
  6. Ensure that TypeName is set to int as shown above
  7. Right Click on INSULATION_TYPE property. Select Custom Attributes > Add/Remove
  8. Add StandardValues custom attribute for newly created INSULATION_TYPE property as shown.
  9. Click on OK.
  10. Scroll down to StandardValues custom attribute. Right Click on ValueMap > Add element.
  11. Enter the desired display string to add these values in drop-down list for Insulation Type property.
  12. Add another custom attribute Category & enter the fields as shown below.
  13. Save the settings.
  14. Using Bentley Class Editor, open OpenPlant_Supplemental_Tagging.01.07. ecschema from below location
  15. Navigate to Piping Network System class, switch to Properties tab.
  16. Add a new property as INSULATION_TYPE as shown.
  17. Add Category custom attribute and enter details as shown.
  18. Search “NAME” property & update EC Expression as well Parser as shown.
    ECExpression: this.UNIT_NAME & "-" & this.SERVICE_NAME & "-" & this.NUMBER & "-" &  this.SPECIFICATION & "(" & this.INSULATION_TYPE & ")"
    Parser: ^[?\w]*-[?\w]*-(?<NUMBER>[?\w]*)-(?<SPECIFICATION>[a-zA-Z]{1,20})([?\w]*)
  19. Save all the settings & verify the result.
communities.bentley.com/.../how-to-addremove-tools-in-main-task-of-openplant-pid
communities.bentley.com/.../273187
