| Applies To | ||
| Product(s): | OpenPlant PID | |
| Version(s): | 08.11.10.XXX & Higher | |
| Environment: | Windows 7/8/10 (64 bit) | |
| Area: | Customization | |
| Subarea: | ||
| Original Author: | Harpreet Singh, Bentley Product Advantage Group |
By default, main task in OpenPlant PID has some tools which are frequently used while building a PID drawing. This task can be modified by making changes in "PIDProjectSymbols.dgnlib" file in your project dataset. You can add tools to this task which are often used or remove the tools which are not required. Below is the snapshot of main task in Out of the Box project.
In this excercise we will add a tool to synchronize the drawing and remove an existing tool.
