Applies To | |||
Product(s): | AECOsim Building Designer | ||
Version(s): | 08.11.09.593 | ||
Environment: | N/A | ||
Area: | Modeling | ||
Subarea: | Compound Cell | ||
Original Author: | Gerard Torres, Bentley Technical Support Group | ||
When user tries to place a stair or railing he gets a message that "Section file is missing please find/load section file".
Only "Schematic" stairs and "Chairrail" railing are working.
Check the configuration variable STRUCTURAL_SHAPES value for the dataset you are using. Both the stairs and railing catalogs will use the structural sections found in the xml defined by the above configuration variable.
