| Version(s): | V8i (08.11.09.866) | ||
| Area: | Dataset | ||
| Subarea: | Migration/Utilities |
Migration of a Dataset and projects to a newer version of AECOsim Building Designer can be accomplished by following the guides linked below.
This is a task that generally should only be undertaken by the people responsible for maintenance of the CAD/BIM systems to ensure that the appropriate company procedures are followed and the required IT security permissions are available.
The best approach is to create a duplicate workspace containing the Dataset and other resources for the new version and a separate location for new and upgraded projects. Projects to be upgraded should be copied to the new location leaving the existing version intact until the migration has been sucessfully completed.
It is frequently advised that active projects should not be upgraded to a new application version (on most CAD/BIM platforms). This is good advice as any significant changes in the IT aspects of a project generally carry some element of risk. However depending on the size of a project, the stage a project has reached and/or on the project duration, version migration may be worth considering if the updates provided by the latest application version offer sufficient productivity or other advantages to justify the time spent on upgrade.
The migration steps are covered in detail in the following:
Updating/Migrating Legacy Building Datasets to AECOsim SS3
Updating/Migrating SS3 Datasets to SS4
Updating/Migrating SS4 Datasets to SS5
