Applies To | |
Product(s): | OpenPlant Modeler |
Version(s): | 08.11.11.XXX (SS6) |
Environment: | Windows 7/8.1/10 (64 bit) |
Area: | Properties |
Subarea: | Pipe Bend - Coordinates |
Original Author: | Rahul Kumar, Bentley Product Advantage Group |
To obtain Pipe Bend Coordinates in OpenPlant Isometrics drawing
While extracting isometrics, it has been found that pipe bend coordinates are required to display on bends for specific use. This can be achieved using Isometric Configuration dialog, & defining a variable inside it. See below steps to verify the result.
In OpenPlant Modeler, select any project and create an arrangement with multiple bends with different Radius.
Launch OpenPlant Isometrics Manager, using Isometric Configuration dialog à select user labels option.
Under Bend Radius and Bend Labels field, change value as shown in below.
R=$(BEND_POINT_RADIUS)D$$(BANGLE)°$(COORD)
Where,
BEND_POINT_RADIUS = It gives Radius info
BANGLE = gives an angle
If above problem still persist, then please create a Service Request and contact Bentley Product Advantage group along with the list of all relevant details to get in depth analysis and for possible solution or workarounds.
communities.bentley.com/.../modifying-the-isometric-content
Bentley's Product advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
