| Version(s): | V8i (08.11.09.866) | ||
| Area: | HVAC | ||
| Subarea: | Design |
I have a rectangular duct with 350mm high . I want to take off with round duct of 315mm.
AECOsim modelled a Ø250mm take off and create a centric reduce of Ø250 x Ø315mm
The only way will be by placing a transition from rectangular to round, give the transition the desired dimensions and then connect round duct ( or vise versa).
