| Version(s): | CONNECT Edition (10.0.0.154) | ||
| Area: | Drawing Views | ||
| Subarea: | N/A |
AECOsim Building Designer CONNECT Edition includes a new, multi-threaded visible edge processing engine that takes advantage of all CPUs and cores of a machine by parallelizing its calculations. This will significantly improve the performance of all operations that involve visible edge processing, such as:
