| Version(s): | 10.00.00.154 | ||
| Area: | General | ||
| Subarea: | Error | ||
While trying to install AECOsim CONNECT Edition, the installation is failing with error code 0x80070642. Installation is not completed.
This error code can be shown for many reason. To understand the proper reason you need to go the 'Error Log' file. Then you have to find from where the error starts. In the below attached screenshot you can find out that this is a problem due to a '.NET 4.5.2' .
You can resolve this issue by following the steps below.
You can then restart the installation process and it will be completed successfully.
