| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.09.XXX (SS5) | 08.11.11.277 (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) |
| Area: | Settings/Attributes |
| Subarea: | |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
To Assign Field Fit Weld Allowances for BOM CutList in OpenPlant Isometrics Manager.
In OpenPlant Isometrics Manager, Field Fit weld allowances has been needed in BOM cut list report to allow extra length of pipe to order which can be further trimmed for end preparation at site. However assigning extra length will not show up in DWG dimension, but it will report in BOM for ordering the extra length. This could be realized using both AutoPLANT Modeler and OpenPlant Modeler user with OpenPlant Isometrics Manager. Check below steps described for both ways.
