| Version(s): | 08.11.09.866 | ||
| Area: | General | ||
| Subarea: | Errors |
Use of Triforma components limits the ability to manipulate models in other applications.
You can solve this issue by opening the building design file in its native application, select all elements in the file, and in the keyin browswer type "TFREMOVE". This will remove the intelligence on the elements in the design file and make them available to manipulate in MicroStation or other applications.
Note: Once the building elements have lost their building data, their Element ID's will also change since they become new elements in the file.
