| Version(s): | 10.00.00.154 | ||
| Environment: | Windows 7 32 bit,Windows 7 64 bit,Windows 8/8.1,Windows 10 | ||
| Area: | General | ||
| Subarea: | N\A |
I have a robust but older system. When I open any file, lines display everywhere all over my drawing (zingers). The problem first occurred when I was still using Windows 7 but has persisted into Windows 10. I completely uninstalled and reinstalled the program and upgraded to 32 GB of memory, but it didn't resolve the issue.
The file should display correctly.
If you still have problems, please open a Service Request or post the issue to the Forum.
