| Version(s): | 10.02.00.35 | ||
| Area: | General | ||
| Subarea: | N\A | ||
User wants to know if the "Isolate" command has been removed from AECOsim Building Designer CONNECT Edition? You could select objects in V8i by right-click and select 'isolate' to display only those elements.
The CONNECT Edition commands are similar but renamed to "Displayset" and is available in the Shift +Right-click pop-up tools. You can check the command out in the below picture.
