Product(s): | AECOsim Building Designer | ||
Version(s): | CONNECT Edition | ||
Environment: | N\A | ||
Area: | Grid Systems | ||
Subarea: | Sketch Grids | ||
How can I create and save Sketch Grids?
Sketch Grids were originally added to the Column Grid tool in AECOsim Building Designer SELECTseries6 to allow you to create a grid system by manually drawing the grid lines. Please go through the following video tutorial that shows how to work with Sketch Grids.
