| Version(s): | 10.00.00.154 | ||
| Area: | General | ||
| Subarea: | N/A |
The DGN file format is unchanged in CONNECT Edition applications including AECOsim Building Designer.
AECOsim Building Designer datasets have been updated from V8i datasets, delta changes documents describing the changes made since SS6 Update 1 are included with the CONNECT Edition datasets.
