| Version(s): | N\A | ||
| Area: | Drawing Views | ||
| Subarea: | Output |
I would like the cached views in my project to get updated automatically over night.
The following steps are to be followed to achieve this:
This workflow would now run AECOsim Building Designer or the file selected by you at your preferred time, which in turn will run the VBA Macro that automatically runs the Batch Process to update the Cached Views and exits the program.
Please note that selecting a file to open in the Task Scheduler helps as it removes the manual step to select a file when AECOsim Building Designer is opened. Please also note that any dialog box that comes up when AECOsim Building Designer is evoked would result in a pause in this process until the dialog box is exited manually. Hence, it is recommended to check whether there are any dialog boxes that come up when AECOsim Building Designer is opened, and get rid of them, if any.
