| Product(s): | OpenPlant Isometrics Manager |
| Version(s): | 08.11.11.294 (SS6Refresh4) & above |
| Environment: | Windows 7/8.1/10 (64-bit) |
| Area: | Settings/Attributes |
| Subarea: | Modifying Symbol |
| Original Author: | Abhijit Bute, Bentley Product Advantage Group |
How to use Isometric custom symbol for Dummy leg/ Trunnion support & How to include them under Support section of Bill of Material.
When generate isometric, Dummy Leg and Trunnion support symbol shows as pipe. Project may have requirement to show customize symbol for Dummy Leg and Trunnion support and include them in Bill of Material support section.
Refer below image support comes under pipe section.
Refer below image support comes under support section.
Below illustrative steps will help to achieve above result.
IE_<EC class>=<symbol>, <scalertype>, <IE type>
Symbol the symbol to use for the support
Scalertype determines the length of the trunnion in the isometric, when not given the Scalertype default to DUMMYPIPE (40 mm length)
IE_TYPE the internal type. This determines further handling in reporting etc. Default to CT_PIPE which makes it appear in the PIPE section of the report, give the support a pipe cut label etc
For example for Single pipe trunnion if add following entry in style.cfg file.
Internally this would be read as:
IE_SINGLE_PIPE_TRUNNION=spt, DUMMY20, CT_SPT
Add following entry in Style.cfg file.
IE_SINGLE_PIPE_TRUNNION=spt, DUMMY20Add new scalertype entry in DUMMY20 in 'Symbolsize.def' file.
DEF B2CP DUMMY20
SEGLEN 20
Add new symbol 'spt' for Trunnion.
Create symbol as per requirement
Note: segment length should be 20 as per mention in symbolsize.def file and define connection point as per mention in below image.Note: Following additional steps need to follow, if requirement must show Trunnion Support under support section in Isometrics bill of material.
Open Style.cfg file in notepad.
Add following entry.
Open ‘Repsortgroup.txt’ in notepad.
Add 'CT_SPT' under Support section.
Similar way same custom symbol can be used for other type of Dummy leg and Trunnion supports
