| Version(s): | CONNECT Edition & V8i | ||
| Area: | Modelling | ||
| Subarea: | Solids Working Area |
Is designing within the center of the Solids Working Area (SWA) still the workflow to follow in AECOsim Building Designer.
When it comes to AECOsim as always, designing within the center of the "Solids Working Area" is the recommended workflow. So far and to my knowledge there has been no indication or information from Development that changes will be made to the SWA recommended workflow or SWA best practices in AECOsim Building Designer.
