Applies To | |||
Product(s): | AECOsim Building Designer | ||
Version(s): | 08.11.09.593 | ||
Environment: | N/A | ||
Area: | Dataset and Content | ||
Subarea: | Database | ||
Original Author: | Robert DiMauro, Bentley Technical Support Group | ||
After modifying the Family name in ATFSCHMCASEWORKFAMILY, the Family and Part are not automatically selected when I use the Place Schematic Casework tool.
This will occur if the new Family and Part name reside under the Single Parts category in Dataset Explorer. The new Family name must reside in Compound Parts in the Architectural_cparts.xml file. This is where the original Casework Families and Parts reside.
