| Applies To | | |
| Product(s): | AutoPLANT Modeler | |
| Version(s): | 08.11.XX.XXX | |
| Environment: | Windows 7 / 8/10 (32/64 bit) | |
| Area: | Customization - AutoPLANT Modeler | |
| Subarea: | | |
| Original Author: | Vidit Ruhela, Bentley Product Advantage Group | |
User requirement is to show the Valve location Coordinates in generated reports from AutoPLANT.
Steps to Accomplish:
Below steps need to be followed to obtain Valve port coordinates in Report Excel file.
When Using SQL Database.
Open SQL Database of the associated Project and in same Database Piping Table add X, Y & Z column as shown below.
Once the X,Y,Z columns are added, save and close the Database.
- Now open Client Machine where AutoPLANT is installed and navigate to the below path and open pipedata.ebs file in notepad.
- Once Opened add the below lines in the Pipedata.ebs file
Add below lines in file as shown in above screenshot.
Dim mypoint As at_point
status = at_Component_getpoint (mypoint, compID, "Port1.LOC")
status = at_DbExt_put (mypoint.X, AT_DB_TABLE_PIPING, AT_CURRENT_DOCUMENT, compID, "X")
status = at_DbExt_put (mypoint.Y, AT_DB_TABLE_PIPING, AT_CURRENT_DOCUMENT, compID, "Y")
status = at_DbExt_put (mypoint.Z, AT_DB_TABLE_PIPING, AT_CURRENT_DOCUMENT, compID, "Z")
After adding above lines save and close pipedata.ebs file.
- Now open Drawing File and generate the report of the selective components.
- Once report is generated go the below path and check for the latest generated report and noticed that now X, Y, Z coordinates are available in the generated report, now this report can be saved anywhere for further reference.
See Also:
https://communities.bentley.com/products/plant/w/plant_design_and_engineering__wiki/35584/customization-autoplant-modeler
Comments or Corrections?
communities.bentley.com/.../settings-attributes---openplant-isometrics-manager
