| Area: | User Interface | ||
| Subarea: | Ribbon |
How to choose Building Design Workflow from Ribbon drop down menu ?
To access the Building Design workflow from the Ribbon follow the following steps:
1. Click on the OpenBuildings Designer icon from the desktop
2. Click the Workflow pull-down list OR
3. If you are out of any active commands, use the keyboard shortcut - press backslash (\) (or for the UK '#') then the appropriate number shown on the resulting pop-up menu alongside the workflow that you want (this is generally the quicker method). Building Design is workflow 1.
You can go through our Learn Server for more information regarding the user interface and features of OpenBuildings Designer. Here is the video for Ribbon Interface to get you started.
