| Area: | GUI | ||
| Subarea: | Ribbon |
In Update 8 we added a new Ribbon Workflow: Building Systems Design:
This contains the MEP discipline tools leaving the Architectural and Structural tools in the Building Design Workflow:
This change gives more space in each workflow for related tools, for instance the (Triforma) Forms tools have been moved from the Modelling workflow to Building Design.
