OPPID - Ss10 What is New
What is New in OpenPlant PID V8i (SELECTseries 10)
V08.11.12
What’s New?
The OpenPlant PID V8i (SELECTseries 10) release is the latest release of our newest Intelligent P&ID Solution.  OpenPlant PID is an Open and interoperable P&ID product based on ISO 15926 that allows any application using the open schema to natively share data.
OpenPlant PID is a productive and easy to use application for production of P&IDs allowing users to capture and reuse information in an open format.  It reduces the time required for design and documentation of facilities and captures process information for system design, plant studies and HAZOP studies across the lifecycle of the asset.
Key Features of OpenPlant PID V8i (SELECTseries 10)
New Features of OpenPlant PID V8i (SELECTseries 10)
SS10 Support:
