| Product(s): | OpenPlant Isometrics Manager CONNECT Edition |
| Version(s): | 10.XX.XX.XXX |
| Environment | Windows 7/8.1/10 (64 bit) |
| Area | Settings/ Attributes |
| Subarea | |
| Original Author | Abhijit Bute, Bentley Product Advantage Group |
In OpenPlant Isometrics Manager, Sometimes user may have requirement to Show specific property break in isometric similar like Spec Break.Following example TEST new Relationship added in AutoPLANT. Two pipes connect having TEST relationship values TEST1 and TEST2.
Following illustrative steps will help to show property break in isometric.
Steps to accomplish
