| Area: | User Interface | ||
| Subarea: | N/A |
A companion feature to the Ribbon interface in AECOsim Building Designer Connect Edition that will be familiar from other Ribbon based user interfaces, Microsoft Office for instance, is the Backstage.
This panel is displayed when you click the "File" tab or press <ALT> + <F>.
Many of the commands found under the Utilities and Building Designer menus in AECOsim Building Designer V8i are now found in the Backstage.
