How to Hide Main Size Annotation for Dummy Leg and Trunnion Support
Product(s):OpenPlant Isometrics Manager CONNECT Edition
Version(s):10.08.XX.XXX & Above
EnvironmentWindows 7/8.1/10 (64 bit)
AreaSettings/ Attributes
SubareaSettings and Attribute
Original AuthorAbhijit Bute, Bentley Product Advantage Group
Some user may have requirement to hide Dummy Leg and Trunnion Support Nominal Size diameter in isometric output.
Following illustrative steps will help to achieve desired result.
  1. Navigate to project location open your desired Isometric style.
    For Ex: C:\ProgramData\Bentley\Plant V8i\Bentley Plant V8i Projects\SAMPLE_METRIC\Config\OpenPlant\Isometrics\styles\IFC\config
  1. Open Style.cfg file in Notepad.
  2. Add following variable at the end of the file.
    DN_ON_DUMMY_LEG= 0
  3. Save the file, generate isometric to review the result.
     DN_ON_DUMMY_LEG= 0  (Disable Main Size display)
           DN_ON_DUMMY_LEG= 1  (Enable Main Size display)
communities.bentley.com/.../settings-attributes---openplant-isometrics-manager-connect-for-autoplant-modeler-connect-edition
Comments or corrections?
