| Area: | Architectural Design | ||
| Subarea: | Walls |
What is the workflow to create walls with Connect Shapes as Top Option?
To create a wall with the "Connect Shapes" option for Top Options, you would need to have a shape which would define the top boundary (in this case, the height) of the wall. You need to select the shape and then click on any data point to accept the selection. Then right-click on any data point. Then click on the data points to draw the wall. You can follow the prompts at the bottom left corner of the application window to properly use the Top Options.
Please watch the following video for a better understanding of the workflow:
