| Area: | Architectural Design | ||
| Subarea: | Walls |
Description
After modelling a wall using the Wall Tool, I want to fillet or chamfer its edge.
Note that applying some modifications to Building elements will convert them to Parametric Solids. They will retain their Family and Parts but will no longer appear in Catalog Schedules. This warning will be displayed:
Under Modify Tab, select 'Fillet Edges' or ' Chamfer Edges'.
For fillet input the value of the fillet 'Radius' and identify the edge to Fillet.
For Chamfer, input the values of the distances and identify the edge to Chamfer.
