Product(s): |
OpenBuildings Designer |
Version(s): |
CONNECT Edition |
Area: |
Architectural |
This wiki will cover how to modify the dimensional parameters (Length, Height or Width) of an already placed Wall with three options.
Option A:
When you select the wall, edit handles will display which will allow to dynamically change the length, height and the width of the wall.
Option B:
Option C:
