| Area: | Structural Design |
Problem Description:
How to change the material density of Concrete? Currently the material density is assigned as 2400kg/m3 (PCC), but if I want to use 2500kg/m3 (RCC) instead, how can we achieve this?
Resolution :
Material density of any structural concrete section is derived from its structural component. You can change the default density value by creating a new concrete Report Component and linking it to your concrete part..
Please go through the video tutorial below and follow the shown steps to achieve desired the results.
