| Area: | Import/Export | ||
| Subarea: | ISM |
For importing pro structural sections and material from other software, importing through ISM file is a very good option. Using this method one can easily map the sectional property and material properties correctly in different software as per the requirement.
Step -1:-
From the ‘Analysis’ ribbon click on ‘New From’
Step -2:-
Then when the ‘Import’ window pop-up follow the path below,
File>Open
Step -3:-
Then the ‘ISM Import’ window will pop up. From there choose the *.ism.dgn file that needs to be imported from the required folder location.
Step -4:-
Then you will again back to the ‘Import’ window. From there you need to choose which type of section you need to import and what will be ‘Instance’ data.
Step -5:-
Then the ‘Section Mapping’ and Material Mapping’ windows will pop up respectively. Choose the required ones from there and click on ‘Import’ for both windows.
Step -6:-
After that, the ISM file will be imported correctly into the DGN file.
