| Product(s): | OpenPlant Project Administrator CONNECT Edition Update 9 |
| Version(s): |
10.09.00.74 |
| Environment: | Windows 10 (64-bit) |
| Area: | Schemas |
| Subarea: | Schema Editor |
| Original Author: | Deepak Singh, Bentley Product Advantage Group |
From OpenPlant Update 9 release, handling of schema editing has been improved and new prompts will be observed when adding any classes to the OpenPlant 3D or OpenPlant PID schema.
For a PlantSight enabled workset, to work smoothly any new addition of classes to OpenPlant 3D or OpenPlant PID requires the same class to be added in OpenPlant schema as well. Up to OpenPlant Update 8, we were following the same approach and making those changes twice. From OpenPlant Update 9, improvement has been done and addition of any classes to OpenPlant PID or OpenPlant 3D will prompt a message about adding the same class to OpenPlant schema as well. This will avoid the duplicate task. In this wiki article, we will add a new class under Generic Instrument class.
If the above problem persists, then please create a Service Request and contact the Bentley Product Advantage group. Please include a list of all relevant details to get in depth analysis for a solution or workaround.
