| Area: | Uninstallation |
Very few times, this issue took place. This is because if any uninstallation does not do properly or any system or internal issue has happened while uninstalling. When if anyone looked at the control panel one can find out that the built is still showing there even after uninstalling it multiple times.
Please follow the steps below,
1. Go to the location written below,
C:\ProgramData\Package Cache
2. In the search window of the file explorer type ‘*.msi’.
3. Then whatever appears as the search result from there delete all the files showing in the screengrab,
4. Try to uninstall the built again from Control Panel.
By this method, you can finally remove the built from your system.
