| Area: | Import/Export | ||
| Subarea: | iTwin |
How can I publish an OpenBuildings Designer file as an iModel using the iModel Hub?
Please go through the video below and follow the steps which will demonstrate how you can create an iModel using iModel Hub.
Here is a YouTube video you can also look into for more information.
www.youtube.com/watch
