OpenPlant | AutoPLANT Knowledge Base
Comprehensive and Interoperable Products for Design and Engineering
With engineering resources in high demand and spread out across multiple-offices, and project schedules continuing to get compressed, project teams require tools that deliver high individual productivity and connect teams so they can work collaboratively, regardless of the systems they are using.
Bentley’s engineering and design tools are used around the world on projects ranging from small retrofits to existing facilities to large, green field facilities whether on land or sea.
Bentley has the most complete and interoperable suite of integrated software, providing leading design and engineering tools covering the range of 2D functional and 3D physical disciplines.
Technotes and FAQs
