| Version(s): | 08.11.11.XXX (SS6) |
| Environment: | Windows 7/8.1/10 (64 bit) & Others |
| Area: | Properties |
| Subarea: | Pipe Bend - Arc Length |
| Original Author: | Rahul Kumar, Bentley Product Advantage Group |
To Define Arc length for Pipe Bends in OpenPlant Modeler.
In OpenPlant Modeler, it has been observed that Length Property for pipe bend calculation displays as twice the arm length of bend, i.e. Length = 2 * Pipe Bend radius along with clamp length (Length to Bend Point, Length after Bend Point).
See image below for default calculation in OpenPlant Modeler.
Length = Length to Bend Point + 2 * Pipe Bend radius + Length After Bend Point.
Where,
Length to Bend Point = 100 mm
Length after Bend Point = 100 mm
Pipe Bend radius = 150 mm
Length = 100 + 2*150 + 100 = 500 mm
Actual calculation should be,
where,
Note –In OpenPlant Modeler unit conversion 1” = 25.4mm
hence desired value would be,
Considering Length to Bend Point = 100 mm & Length after Bend Point = 100 mm,
Updated length would be = 100 + 235.619 + 100 = 435.619 mm
See below steps to overcome this situation by defining a new property in schema through class editor and applying the mathematical expression in EC expression.
If above problem still persist, then please create a Service Request and contact Bentley Product Advantage group along with the list of all relevant details to get in depth analysis and for possible solution or workarounds.
communities.bentley.com/.../properties-openplant-modeler
Bentley's Product advantage Group requests that you please confine any comments you have on this Wiki entry to this "Comments or Corrections?" section. THANK YOU!
