| Product(s): | OpenBuildings Energy Simulator | ||
| Area: | Building Modelling |
Problem Description
When you are using Defaults Manager you can notice that the room dimension interface is not appearing as shown in the screengrab below. How to fix this?
Upon facing such issues, please reset your windows display scale to 100% and then save the changes. Please refer to the screengrab below.
Finally, after changing the display resolution and restarting your Energy Simulator you can see that the room dimension interface is showing properly in the Default Managers tab.
