| | Product(s): | OpenBuildings Designer | |
| | Version(s): | CONNECT Edition | |
| Area: | Platform Tools | |
Problem Description
How can I copy an Excel spreadsheet into an OpenBuildings Designer sheet model?
Please follow the below steps to insert your Excel spreadsheet into a sheet model.
- First, from the Key-in dialog box type “mdl load olecntr” and press Enter.
- Next, go to your sheet model and change the workflow to Drawing. From the Utilities tab choose Utilities > OLE > Insert Object, click on Create from File, browse to the the desired Excel spreadsheet and click OK.
- Next, choose the desired options in the Insert OLE Object dialog, and paste the data from Excel into the sheet model.
- Finally, you can see that the data from the Excel spreadsheet has been successfully inserted in your sheet model.
